I am using the checkmk built_in metrics_info to render time values in seconds and it correctly displays a time series graph in my custom plugin.
However, values smaller than 500 ns are rendered to 0 sec. The smallest value it displays in the graph is 1 microsecond.
I noticed in the built in NTP plugin checkmk renders nanosecond values. Does checkmk uses there a different method to render the values?
As the value is stored as a float with the base unit seconds it could be that the precision of the RRD storing it is not high enough. But that’s just a guess.
def _serialize_value(x: Optional[float]) -> str:
return "" if x is None else ("%.6f" % x).rstrip("0").rstrip(".")
Older 1.5.0: cmk_base/checking.py
def _convert_perf_value(x):
if x is None:
return ""
elif isinstance(x, six.string_types):
return x
elif isinstance(x, float):
return ("%.6f" % x).rstrip("0").rstrip(".")
return str(x)
All CheckMK versions I’ve checked so far contains this conversion before submitting data to core. Most likely it might have been a design decision in the past. Does it still make sense to keep it?
