CMK version: 2.0.0p17 (CEE) OS version: Debian Bullseye
does not work:
<Printer 8.2-A3-Color-1>
</Printer>
works:
<Printer gw0600a>
</Printer>
If I temporarily change the name by removing the dot from the name, everything works. Unfortunately I cannot change the name permanently as this is a naming convention.
Is it possible that dots will be allowed in the plugin in the future?
this is the output from the mk_cups_queues plugin.
So when I run the plugin directly on the console, I get the incorrect output.
CPRINTCONF=/etc/cups/printers.conf
if [ -r "$CPRINTCONF" ] ; then
LOCAL_PRINTERS=$(perl -ne '/<(?:Default)?Printer ([\w-]+)>/ && print "$1\n"' $CPRINTCONF)
When I read the $ CPRINTCONF variable, everything is still correct. The $ LOCAL_PRINTERS variable then only contains the printer without a period in the name. So the Perl command must be responsible for it. I can certainly change that temporarily until the next update, but it should be permanent.
You can write a mail to feedback@checkmk.com or open a ticket as enterprise customer. My suggestion was for a quick fix, you can revert this back to standard if you got the official fix.
