hallo,
das plugin mk_filestat crasht andauerend wenn defaults ausgeführt wird
mit dem parmameter “output: count_only” funktioniert es. mit standard (output: file_stats) crusht er.
benutze aktuell noch eine test version von der Appliance → 2.1.0p3.cfe
config datei :
Agent-Output
Output GUI checkmk
Crash Report:
Exception :
ValueError ('details' must be non-empty str or None, got )
Traceback :
result = _aggregate_results(
File "/omd/sites/checkmkmo/lib/python3/cmk/base/agent_based/checking/__init__.py", line 578, in _aggregate_results
perfdata, results = _consume_and_dispatch_result_types(subresults)
File "/omd/sites/checkmkmo/lib/python3/cmk/base/agent_based/checking/__init__.py", line 622, in _consume_and_dispatch_result_types
for subr in subresults:
File "/omd/sites/checkmkmo/lib/python3/cmk/base/api/agent_based/register/check_plugins.py", line 94, in filtered_generator
for element in generator(*args, **kwargs):
File "/omd/sites/checkmkmo/lib/python3/cmk/base/api/agent_based/register/check_plugins_legacy.py", line 195, in check_result_generator
yield from _create_new_results_with_details(subresults[idx:])
File "/omd/sites/checkmkmo/lib/python3/cmk/base/api/agent_based/register/check_plugins_legacy.py", line 227, in _create_new_results_with_details
yield Result(
File "/omd/sites/checkmkmo/lib/python3/cmk/base/api/agent_based/checking_classes.py", line 367, in __new__
state, summary, details = _create_result_fields(**kwargs)
File "/omd/sites/checkmkmo/lib/python3/cmk/base/api/agent_based/checking_classes.py", line 405, in _create_result_fields
raise ValueError(f"'{name}' must be non-empty str or None, got {var}")
vielen Dank im voraus :))
