After upgrading to 2.1.0p17 all of our slavesites mknotifyd cant start.
Logs says the following, so I turned off the encryption and it started ok.
But I dont want to this to be unencrypted so is this a known bug and is there a fix in the works?
2022-12-13 10:02:42,570 [20] [cmk.mknotifyd] -----------------------------------------------------------------
2022-12-13 10:02:42,570 [20] [cmk.mknotifyd] Check_MK Notification Spooler version 2.1.0p17 starting
2022-12-13 10:02:42,571 [20] [cmk.mknotifyd] Log verbosity: 0
2022-12-13 10:02:42,584 [20] [cmk.mknotifyd] Daemonized with PID 2545001.
2022-12-13 10:02:42,594 [40] [cmk.mknotifyd] FATAL ERROR:
File “/omd/sites/halcyon/lib/python3/cmk/cee/mknotifyd/main.py”, line 307, in main
run_notifyd(args, config, paths, start_time)
File “/omd/sites/halcyon/lib/python3/cmk/cee/mknotifyd/main.py”, line 62, in run_notifyd
connection_manager.initialize_stunnel()
File “/omd/sites/halcyon/lib/python3/cmk/cee/mknotifyd/connection_manager.py”, line 192, in initialize_stunnel
config: str = create_stunnel_config_from_mknotifyd_config(
File “/omd/sites/halcyon/lib/python3/cmk/cee/mknotifyd/connection_manager.py”, line 46, in create_stunnel_config_from_mknotifyd_config
if incoming and incoming[“encryption”] != “unencrypted”:
KeyError: ‘encryption’
