MKP Installation
How does one install one of the MKP’s from the CheckMK Exchange?!? After searching the interwebs its noted the simple and direct method of typing in Extension isn’t available on the free version???
If that’s the case how does one install these files into the system? :thinking:
Login as a site user and type mkp in your cli, then you should see all available options.
Just adding the link to the relevant docs so you can read it up yourself:
