CMK version: 2.0.0p22.cee
OS version: Appliance
The Check is displayed correct in TB but the Graphic is in MB
The one from my modified Version is this:
The Code of the modified check
#!/usr/bin/env python3
# -*- coding: utf-8 -*-
# Copyright (C) 2019 tribe29 GmbH - License: GNU General Public License v2
# This file is part of Checkmk (https://checkmk.com). It is subject to the terms and
# conditions defined in the file COPYING, which is part of this source code package.
# NOTE: Careful when replacing the *-import below with a more specific import. This can cause
# problems because it might remove variables from the check-context which are necessary for
# resolving legacy discovery results such as [("SUMMARY", "diskstat_default_levels")]. Furthermore,
# it might also remove variables needed for accessing discovery rulesets.
from cmk.base.check_legacy_includes.df import * # pylint: disable=wildcard-import,unused-wildcard-import
from cmk.base.check_legacy_includes.size_trend import * # pylint: disable=wildcard-import,unused-wildcard-import
PoolEntry = collections.namedtuple(
"EternusProvisioningPool",
["capacity", "usage", "available"],
def parse_fjdarye200_pools_combined(info):
parsed = {}
capacity_combined = 0
usage_combined = 0
for pool_id, capacity, usage in info:
try:
capacity_combined = capacity_combined+int(capacity)
usage_combined=usage_combined+int(usage)
except ValueError:
pass
parsed["Combined"] = PoolEntry(
capacity=int(capacity_combined),
usage=int(usage_combined),
available=int(capacity_combined) - int(usage_combined),
return parsed
@get_parsed_item_data
def check_fjdarye200_pools_combined(item, params, entry):
return df_check_filesystem_single(
item,
entry.capacity,
entry.available,
0,
None,
None,
params,
check_info["fjdarye200_pools_combined"] = {
"parse_function": parse_fjdarye200_pools_combined,
"inventory_function": discover(),
"check_function": check_fjdarye200_pools_combined,
"service_description": "Thin Provisioning Pools %s",
"snmp_info": (
".1.3.6.1.4.1.211.1.21.1.150.14.5.2.1",
"1", # fjdaryMgtTpPoolNumber
"3", # fjdaryMgtTpPoolTotalCapacity
"4", # fjdaryMgtTpPoolUsedCapacity
"snmp_scan_function": lambda oid: oid(".1.3.6.1.2.1.1.2.0") == ".1.3.6.1.4.1.211.1.21.1.150",
"default_levels_variable": "filesystem_default_levels",
"group": "filesystem",
"has_perfdata": True,
