Hey guys, after I set up LDAP successfully and adding /opt/omd/sites/dev/etc/check_mk/multisite.d/wato/user_connections.mk
to our deploy script, I would like to update the Roles & permissions and change some defaults in our setup. How can I do this in a scripted/automated way, when we redeploy our CMK instance?
No file in conf.d/wato is changed, after I change it in the webui, see
Here is a ls -l (contacts changes because I set the LDAP sync to every 10 minutes):
root@ce9874436c12:/opt/omd/sites/dev/etc/check_mk/conf.d/wato# ls -l
total 56
-rw-rw---- 1 dev dev 8721 Mar 23 13:22 contacts.mk
-rw-rw---- 1 dev dev 1780 Mar 23 13:10 global.mk
-rw-rw---- 1 dev dev 140 Mar 23 13:10 groups.mk
-rw-rw---- 1 dev dev 4154 Mar 23 13:10 hosts.mk
-rw-rw---- 1 dev dev 1424 Mar 23 13:10 hosts.pkl
-rw-r--r-- 1 root root 766 Mar 23 13:10 notifications.mk
-rw-rw---- 1 dev dev 4157 Mar 23 13:10 rules.mk
-rw-rw---- 1 dev dev 665 Mar 23 13:10 tags.mk
So, which .mk file do I need to change to edit the defaults? I can’t find any API request which lets me change the defaults for Roles & permissions too
