Hi there,
did anyone try already to monitor LANCOM Could managed network devices?
They also (still) have SNMP, but I thought that monitoring its REST API is perhaps a more performant approach.
Thanks & regards,
Simon
Hi there,
Thanks & regards,
Simon
Locks like nearly the same what Meraki does Cloud + local SNMP if you want.
Also in the Meraki Cloud you first pull a list of devices and then for every device found you fetch the wanted data.
Sounds good. I will have a look into that!
Thanks Andreas!
/Simon
I want to do the exact same thing. Can you explain me how you did this. I tried but the documentation of LANCOM is very unclear.
I’ll try to find this out (did not work with this customer for a longer time).
Regards,
Simon
Thanks, I hope you can find this out!
Sorry, the customer did not continue to work with LANCOM…
