Hi dear checkmk Forum
What I already tried
We have a local S3 storage. The Connection is over AWS like this:
s3 = boto3.resource('s3',endpoint_url='https://s3.domail.tld')
(in this Example the Access- and SecretKey is saved in the AWS Config).
In the /cmk/special_agents/agent_aws.py we have the line 4344:
session = create_session(args.access_key_id, args.secret_access_key, region)
So, there is no “Endpoint URL” defined. Also the boto.session command does not include the parameter endpoint_url.
I tried on an test installation from checkmk with the boto3.resource and with an endpoint_url - till the test installation ends in a 500 ServerError.
My target
The “how” is not so important, but I should have some monitoring datas in the checkmk.
Is there a way to implement the local S3 Storage in checkmk?
Thanks a lot for your help and inputs,
Oli
