@andreas-doehler , could you please tell me if you had some time to check the ovirt plugin ![]()
I have no systems with ovirt virtualization at the moment and so i cannot look for this problem. Sorry
@andreas-doehler , ok thank you
. I will update this thread if I am able to find a solution.
Based on the below forum,
I was able to solve the “df_check_filesystem_single” error by modifying check_default_parameters to df.FILESYSTEM_DEFAULT_PARAMS
Before.
register.check_plugin(
name='ovirt_storage_domains',
service_name='oVirt Storage Domain %s',
discovery_function=discovery_ovirt_storage_domains,
check_function=check_ovirt_storage_domains,
check_ruleset_name="ovirt_storage_domains",
check_default_parameters=df.FILESYSTEM_DEFAULT_LEVELS,
After,
check_default_parameters=df.FILESYSTEM_DEFAULT_PARAMS,
Thank you,
Benson Thomas
