ano
(Andry OELIHARIVONY)
October 9, 2020, 12:30pm
1
Hello team ,
I have this issue which is appearing sometimes in check_mk in some machines regarding the mount options :Mount options of / WARN - Missing: seclabel
As solution here : https://monitoring-portal.org/woltlab/index.php?thread/27285-check-mk-mount-options-wrong-warning-status/
I have to make a reinvetory : cmk -II [hosts ] and cmk -R
But my problem is the route cause , why this is appearing because I didn’t change the host or the mount options ?
It is a check_mk bug ?
Kr ,
Andry
This is no bug. The mount options are changed most times if you install bigger updates. I saw this behavior many time with updates from Ubuntu 16.04 to 18.04 or also some Debian release changes.
In the end it is normal behavior.
ano
October 12, 2020, 7:48am
3
@andreas-doehler thanks for your answer . it is clear for me now
Kind regards ,
Andry
system
(system)
Closed
October 12, 2021, 7:48am
4
