Hi all,
it’s possible to use 2FA with Check_MK raw 1.6 version?
Thank you all
Hi all,
Thank you all
Basically all what apache supports could be used for checkmk. You just need to know apache configuration.
Out of the box its not available but you may use kerberos:
Kerberos supports 2FA
