Dear All,
I am trying to monitor custom port and service in centos server.
can some one please help me to install the same.
Thanks in Advance.
Regards,
Sudherson E
Dear All,
Thanks in Advance.
Regards,
Sudherson E
Hi @sutherson
You can e.g. monitor a TCP port with the rule “Check connecting to a TCP port” as active check. If you are using a CMK server with 1.6 or above, the default CMK agent checks include “systemd services”.
HTH,
Openmindz
Hi Openmindz,
Thanks for your information.
currently we are using Check-MK 1.4 version. please help on this.
Regards,
Sudherson E
Hi @sutherson
OK, so… time for an upgrade…
No, seriously, what kind of service do you want to monitor?
Openmindz
Hi ,
we need to monitor the custom port number like 9000
