CMK version: Check_MK 1.5
OS version:SUSE Linux
When configured the rules for monitor the file handler , agent not showing any date
Plugin name:- filehandler
You need to deploy the agent plugin mk_filehandler
to gather the data for this check
If you run the free or enterprise edition you can use this extension to use the agent bakery for this task: Checkmk Exchange
Thank you for update,
we are running on Check_mk version 1.5 and plugin supported for 2.0 above version(This version requires Checkmk version 2.0.0 or higher), if possible share the link for 1.5 version plugins library.
This version is not supported any more. You really should plan to upgrade soon.
Thanks for update, if you have document to upgrade the directly Check_MK 1.5 to Check_mk 2.x version or need to perform version by version like 1.6 then 2–> 2. X version.
please let us know how to procced here
You need to first upgrade to 1.6 then to 2.0 and then to 2.1
You should find instructions in the documentation on https://docs.checkmk.com/
