The WATO Service Configuration only retrieves environment information for the internal sensors and not for the remote sensors for model WATCHDOG 15-P NPS. The snmpwalk output retrieves information for all sensors. Is there a solution for this? Best Regards.
**Output of “cmk --debug -vvn hostname”:
Checkmk version 2.0.0p17
Trying to acquire lock on /omd/sites/testing/var/check_mk/license_usage/next_run
Got lock on /omd/sites/testing/var/check_mk/license_usage/next_run
Trying to acquire lock on /omd/sites/testing/var/check_mk/license_usage/history.json
Got lock on /omd/sites/testing/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/testing/var/check_mk/license_usage/history.json
Released lock on /omd/sites/testing/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/testing/var/check_mk/license_usage/next_run
Released lock on /omd/sites/testing/var/check_mk/license_usage/next_run
Loading autochecks from /omd/sites/testing/var/check_mk/autochecks/xxx.xxx.xxx.xxx.mk
+ FETCHING DATA
[cpu_tracking] Start [7f6dfe1b34f0]
[SNMPFetcher] Fetch with cache settings: SNMPFileCache(base_path=PosixPath('/omd/sites/testing/tmp/check_mk/data_source_cache/snmp/xxx.xxx.xxx.xxx'), max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
Not using cache (Too old. Age is 16 sec, allowed is 0 sec)
No persisted sections loaded
SNMP scan:
Getting OID .1.3.6.1.2.1.1.1.0: Executing SNMP GET of .1.3.6.1.2.1.1.1.0 on xxx.xxx.xxx.xxx
=> [b'Geist Watchdog'] OCTETSTR
b'Geist Watchdog'
Getting OID .1.3.6.1.2.1.1.2.0: Executing SNMP GET of .1.3.6.1.2.1.1.2.0 on xxx.xxx.xxx.xxx
=> [b'.1.3.6.1.4.1.21239.42.1.31'] OBJECTID
Getting OID .1.3.6.1.2.1.2.2.1.*: Executing SNMP GETNEXT of .1.3.6.1.2.1.2.2.1 on xxx.xxx.xxx.xxx
=> [b'1'] INTEGER32
b'1'
Using cached OID .1.3.6.1.2.1.1.1.0: 'Geist Watchdog'
Using cached OID .1.3.6.1.2.1.1.2.0: '.1.3.6.1.4.1.21239.42.1.31'
SNMP scan found if snmp_uptime
Trying to acquire lock on /omd/sites/testing/tmp/check_mk/snmp_scan_cache/xxx.xxx.xxx.xxx.xxx.xxx.xxx.xxx
Got lock on /omd/sites/testing/tmp/check_mk/snmp_scan_cache/xxx.xxx.xxx.xxx.xxx.xxx.xxx.xxx
Releasing lock on /omd/sites/testing/tmp/check_mk/snmp_scan_cache/xxx.xxx.xxx.xxx.xxx.xxx.xxx.xxx
Released lock on /omd/sites/testing/tmp/check_mk/snmp_scan_cache/xxx.xxx.xxx.xxx.xxx.xxx.xxx.xxx
if: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Executing BULKWALK of ".1.3.6.1.2.1.2.2.1.1" on xxx.xxx.xxx.xxx
.1.3.6.1.2.1.2.2.1.1.1 => [b'1'] 'INTEGER32'
Executing BULKWALK of ".1.3.6.1.2.1.2.2.1.2" on xxx.xxx.xxx.xxx
.1.3.6.1.2.1.2.2.1.2.1 => [b'eth0'] 'OCTETSTR'
Executing BULKWALK of ".1.3.6.1.2.1.2.2.1.3" on xxx.xxx.xxx.xxx
.1.3.6.1.2.1.2.2.1.3.1 => [b'6'] 'INTEGER'
Executing BULKWALK of ".1.3.6.1.2.1.2.2.1.5" on xxx.xxx.xxx.xxx
.1.3.6.1.2.1.2.2.1.5.1 => [b'100000000'] 'GAUGE'
Executing BULKWALK of ".1.3.6.1.2.1.2.2.1.8" on xxx.xxx.xxx.xxx
.1.3.6.1.2.1.2.2.1.8.1 => [b'1'] 'INTEGER'
Executing BULKWALK of ".1.3.6.1.2.1.2.2.1.10" on xxx.xxx.xxx.xxx
.1.3.6.1.2.1.2.2.1.10.1 => [b'0'] 'COUNTER'
Executing BULKWALK of ".1.3.6.1.2.1.2.2.1.11" on xxx.xxx.xxx.xxx
.1.3.6.1.2.1.2.2.1.11.1 => [b'0'] 'COUNTER'
Executing BULKWALK of ".1.3.6.1.2.1.2.2.1.12" on xxx.xxx.xxx.xxx
.1.3.6.1.2.1.2.2.1.12.1 => [b'0'] 'COUNTER'
Executing BULKWALK of ".1.3.6.1.2.1.2.2.1.13" on xxx.xxx.xxx.xxx
.1.3.6.1.2.1.2.2.1.13.1 => [b'0'] 'COUNTER'
Executing BULKWALK of ".1.3.6.1.2.1.2.2.1.14" on xxx.xxx.xxx.xxx
.1.3.6.1.2.1.2.2.1.14.1 => [b'0'] 'COUNTER'
Executing BULKWALK of ".1.3.6.1.2.1.2.2.1.16" on xxx.xxx.xxx.xxx
.1.3.6.1.2.1.2.2.1.16.1 => [b'0'] 'COUNTER'
Executing BULKWALK of ".1.3.6.1.2.1.2.2.1.17" on xxx.xxx.xxx.xxx
.1.3.6.1.2.1.2.2.1.17.1 => [b'0'] 'COUNTER'
Executing BULKWALK of ".1.3.6.1.2.1.2.2.1.18" on xxx.xxx.xxx.xxx
.1.3.6.1.2.1.2.2.1.18.1 => [b'0'] 'COUNTER'
Executing BULKWALK of ".1.3.6.1.2.1.2.2.1.19" on xxx.xxx.xxx.xxx
.1.3.6.1.2.1.2.2.1.19.1 => [b'0'] 'COUNTER'
Executing BULKWALK of ".1.3.6.1.2.1.2.2.1.20" on xxx.xxx.xxx.xxx
.1.3.6.1.2.1.2.2.1.20.1 => [b'0'] 'COUNTER'
Executing BULKWALK of ".1.3.6.1.2.1.2.2.1.21" on xxx.xxx.xxx.xxx
.1.3.6.1.2.1.2.2.1.21.1 => [b'0'] 'GAUGE'
Executing BULKWALK of ".1.3.6.1.2.1.2.2.1.6" on xxx.xxx.xxx.xxx
.1.3.6.1.2.1.2.2.1.6.1 => [b'\x04\x91b\x89dG'] 'OCTETSTR'
Executing BULKWALK of ".1.3.6.1.2.1.1.1" on xxx.xxx.xxx.xxx
.1.3.6.1.2.1.1.1.0 => [b'Geist Watchdog'] 'OCTETSTR'
Executing BULKWALK of ".1.3.6.1.2.1.1.4" on xxx.xxx.xxx.xxx
.1.3.6.1.2.1.1.4.0 => [b'computerops@rpi.edu'] 'OCTETSTR'
Executing BULKWALK of ".1.3.6.1.2.1.1.5" on xxx.xxx.xxx.xxx
.1.3.6.1.2.1.1.5.0 => [b'Geist Watchdog'] 'OCTETSTR'
Executing BULKWALK of ".1.3.6.1.2.1.1.6" on xxx.xxx.xxx.xxx
.1.3.6.1.2.1.1.6.0 => [b''] 'OCTETSTR'
Executing BULKWALK of ".1.3.6.1.2.1.1.3" on xxx.xxx.xxx.xxx
.1.3.6.1.2.1.1.3.0 => [b'48774387'] 'TICKS'
Executing BULKWALK of ".1.3.6.1.2.1.25.1.1" on xxx.xxx.xxx.xxx
Executing SNMP GET of .1.3.6.1.2.1.25.1.1 on xxx.xxx.xxx.xxx
=> [None] NOSUCHOBJECT
watchdog_sensors: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Executing BULKWALK of ".1.3.6.1.4.1.21239.5.1.1.2" on xxx.xxx.xxx.xxx
.1.3.6.1.4.1.21239.5.1.1.2.0 => [b'3.4.0'] 'OCTETSTR'
Executing BULKWALK of ".1.3.6.1.4.1.21239.5.1.1.7" on xxx.xxx.xxx.xxx
.1.3.6.1.4.1.21239.5.1.1.7.0 => [b'0'] 'INTEGER'
Executing BULKWALK of ".1.3.6.1.4.1.21239.5.1.2.1.3" on xxx.xxx.xxx.xxx
.1.3.6.1.4.1.21239.5.1.2.1.3.1 => [b'Geist WD15'] 'OCTETSTR'
Executing BULKWALK of ".1.3.6.1.4.1.21239.5.1.2.1.4" on xxx.xxx.xxx.xxx
.1.3.6.1.4.1.21239.5.1.2.1.4.1 => [b'1'] 'GAUGE'
Executing BULKWALK of ".1.3.6.1.4.1.21239.5.1.2.1.5" on xxx.xxx.xxx.xxx
.1.3.6.1.4.1.21239.5.1.2.1.5.1 => [b'729'] 'INTEGER'
Executing BULKWALK of ".1.3.6.1.4.1.21239.5.1.2.1.6" on xxx.xxx.xxx.xxx
.1.3.6.1.4.1.21239.5.1.2.1.6.1 => [b'29'] 'INTEGER'
Executing BULKWALK of ".1.3.6.1.4.1.21239.5.1.2.1.7" on xxx.xxx.xxx.xxx
.1.3.6.1.4.1.21239.5.1.2.1.7.1 => [b'388'] 'INTEGER'
Executing BULKWALK of ".1.3.6.1.4.1.21239.5.1.2.1.8" on xxx.xxx.xxx.xxx
Executing SNMP GET of .1.3.6.1.4.1.21239.5.1.2.1.8 on xxx.xxx.xxx.xxx
Write data to cache file /omd/sites/testing/tmp/check_mk/data_source_cache/snmp/checking/xxx.xxx.xxx.xxx
Trying to acquire lock on /omd/sites/testing/tmp/check_mk/data_source_cache/snmp/checking/xxx.xxx.xxx.xxx
Got lock on /omd/sites/testing/tmp/check_mk/data_source_cache/snmp/checking/xxx.xxx.xxx.xxx
Releasing lock on /omd/sites/testing/tmp/check_mk/data_source_cache/snmp/checking/xxx.xxx.xxx.xxx
Released lock on /omd/sites/testing/tmp/check_mk/data_source_cache/snmp/checking/xxx.xxx.xxx.xxx
[cpu_tracking] Stop [7f6dfe1b34f0 - Snapshot(process=posix.times_result(user=0.45999999999999996, system=0.03, children_user=0.0, children_system=0.0, elapsed=6.820000000298023))]
[cpu_tracking] Start [7f6dfe08f460]
No piggyback files for 'xxx.xxx.xxx.xxx'. Skip processing.
[PiggybackFetcher] Fetch with cache settings: NoCache(base_path=PosixPath('/omd/sites/testing/tmp/check_mk/data_source_cache/piggyback/xxx.xxx.xxx.xxx'), max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
[cpu_tracking] Stop [7f6dfe08f460 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
[cpu_tracking] Start [7f6e001931c0]
+ PARSE FETCHER RESULTS
-> Add sections: ['if', 'snmp_info', 'snmp_uptime', 'watchdog_sensors']
-> Add sections: []
Received no piggyback data
Loading item states
Trying to acquire lock on /omd/sites/testing/tmp/check_mk/counters/xxx.xxx.xxx.xxx
Got lock on /omd/sites/testing/tmp/check_mk/counters/xxx.xxx.xxx.xxx
Releasing lock on /omd/sites/testing/tmp/check_mk/counters/xxx.xxx.xxx.xxx
Released lock on /omd/sites/testing/tmp/check_mk/counters/xxx.xxx.xxx.xxx
Dew point 1 38.8 °F
Humidity 1 29.0%
Interface 1 [eth0], (up), MAC: xx.xx.xx.xx.xx.xx, Speed: 100 MBit/s, In: 0.00 B/s (0%), Out: 0.00 B/s (0%)
SNMP Info Geist Watchdog, Geist Watchdog, , computerops@rpi.edu
Temperature 1 72.9 °F
Uptime Up since Feb 16 2022 12:57:51, Uptime: 5 days 15 hours
Watchdog 1 available, Location: Geist WD15
[cpu_tracking] Stop [7f6e001931c0 - Snapshot(process=posix.times_result(user=0.010000000000000231, system=0.010000000000000009, children_user=0.0, children_system=0.0, elapsed=0.009999999776482582))]
[snmp] Success, execution time 6.8 sec | execution_time=6.830 user_time=0.470 system_time=0.040 children_user_time=0.000 children_system_time=0.000 cmk_time_snmp=6.330 cmk_time_agent=0.000
