When we full scan for one device , getting below error .Please help me to resolve this.
Starting job…
FETCHING DATA
[snmp] Execute data source
ERROR: SNMP error
snmpget: Timeout
SNMP scan failed: Cannot fetch system description OID .1.3.6.1.2.1.1.1.0. This might be OK for some bogus devices. In that case please configure the ruleset “Hosts without system description OID” to tell Check_MK not to fetch the system description and system object OIDs.
No piggyback files for ‘de03-sw-s901’. Skip processing.
No piggyback files for ‘10.39.224.53’. Skip processing.
Completed.
Device details -
Hardware
Nexus9000 in ACI Fabric mode – Spine and Leaf switches, APIC
Cisco NX-OS 14.2(4i)
when we test the snmp , snmp test works good .
“Retry this test”)](javascript:cmk.host_diagnose.start_test(‘snmpv3’, ‘test’, ‘1592817396/3543042676’) sysDescr: Cisco NX-OS™ aci, Software (aci-n9000-system), Version 14.2(4i), RELEASE SOFTWARE Copyright (c) 2002-2015 by Cisco Systems, Inc. Compiled 2020/04/21 09:45:55
sysContact: d
sysName: de03-sw-s901
sysLocation: DNPC Paderborn
On command line do a “cmk --debug -D hostname’” and check the shown SNMP config if correct. Then do a “cmk --debug -vvI hostname’” to make a discovery. Do you get some error messages there?
Discovering services on: de03-sw-s901
de03-sw-s901:
FETCHING DATA
[agent] No persisted sections loaded
[agent] Not using cache (Does not exist)
[agent] Execute data source
[agent] Connecting via TCP to 10.39.224.53:6556 (5.0s timeout)
[agent] ERROR: timed out
File “/omd/sites/test/bin/cmk”, line 94, in
File “/omd/sites/test/lib/python/cmk_base/modes/init.py”, line 72, in call
return mode.handler_function(*handler_args)
File “/omd/sites/test/lib/python/cmk_base/modes/check_mk.py”, line 1498, in mode_discover
discovery.do_discovery(hostnames, options.get(“checks”), options[“discover”] == 1)
File “/omd/sites/test/lib/python/cmk_base/discovery.py”, line 134, in do_discovery
multi_host_sections = _get_host_sections_for_discovery(sources, use_caches=use_caches)
File “/omd/sites/test/lib/python/cmk_base/discovery.py”, line 906, in _get_host_sections_for_discovery
return sources.get_host_sections(max_cachefile_age)
File “/omd/sites/test/lib/python/cmk_base/data_sources/init.py”, line 279, in get_host_sections
host_sections_from_source = source.run()
File “/omd/sites/test/lib/python/cmk_base/data_sources/abstract.py”, line 133, in run
raw_data, is_cached_data = self._get_raw_data()
File “/omd/sites/test/lib/python/cmk_base/data_sources/abstract.py”, line 182, in _get_raw_data
raw_data = self._execute()
File “/omd/sites/test/lib/python/cmk_base/data_sources/tcp.py”, line 100, in _execute
s.connect((self._ipaddress, port))
File “/omd/sites/test/lib/python2.7/socket.py”, line 228, in meth
return getattr(self._sock,name)(*args)
socket.timeout: timed out
I want to know what happens if you do this command on the CLI?
It is important what happens there. Your config of this host looks ok but i need to see what happens then on the CLI.
