Hi all,
I am working with Check_mk version 2.0.0p4 in email notifications. I found that in the previous version and the ones I am using have a difference in the names in the email notifications, this specifically in the option “Additional plugin output”
When the mail is received in the previous version in the table it was called “Plug-in output” and now in the new version it is called “summary”
Also note that when the recovery or critical mail arrives it does not always bring the data of “Critical” and “OK” which I need because there is an automation that they are doing and they need those values that in the previous version if they appeared.
Does anyone know how we can make it look like the previous version?
New version
Regards.
Victor Pineda
