Notification method Opsgenie behind proxy
I have check_mk version raw 1.6.0p6 running and would like to use Opsgenie notification method. For the api call I need to use a proxy to access the internet. I tried to solve this by configuring a global http_proxy within check_mk but it didn`t work. Does someone have an idea how to fix this?
Thanks in advance!
Kind regards,
Jens
Hi @jhrc, Welcome to the community !
I would go for editing the script in the request I would add the proxy.
I’ll come back with more info
Edit:
I was checking the plugin and its dependencies, if you check on /opt/omd/versions/1.6.0p8.cee.demo/lib/python/opsgenie/service.py it has proxy values. Take a look there, currently I don’t have access to cmk so I installed the demo.
