I am new to checkmk and stuck with not running notifications.
My setup is:
Synology NAS 720+ with DSM 6.2
Checkmk is running as docker image checkmk-check-mk-raw2
version: 2.0.0b3
Mail system based on synology package MailPlus Server
Fallback email address for notifications defined
Ideally, Check_MK uses /usr/sbin/sendmail to send notifications, everything else
depends on the local MTA.
However,there are two active checks configurable via WATO:
Here you can specify the SMTP server
Check Email Delivery
This active check sends out special E-Mails to a defined mail address using the SMTP protocol and then tries to receive these mails back by querying the inbox of a IMAP or POP3 mailbox. With this check you can verify that your whole mail delivery progress is working.
Check SMTP to access services
This check uses check_smtp from the standard Nagios plugins in order to try the response of an SMTP server.
I am afraid there is nothing like that when you want to setup notifications.
If you use Mailplus, then you have configure the Mailplus so that atleast it can send emails. The same way I did it for postfix. Just installed Postfix and I had to make sure that the mail command works. If that works, then no extra configuration needed on Checkmk side.
@ilexpl01 Did you ever get this working? Im in the same boat as you, new to Check_mk and I have it loaded up in my Synology. How do I get this thing to send an email when it detects the host down? What do I need to do in the Synology? Thanks so much!
