OpenHardwareMonitor Plugins
I have multiple hosts running Windows and I would like to get all information possible via OpenHardwareMonitor. I am running Checkmk Free in a Docker Container on Ubuntu 20.04 and the hosts all connect via WAN. I have OpenHardwareMonitor CLI deployed and it shows temperatures and fan speeds (by the way: can I rename single sensors?). According to Check Plug-Ins Catalog (checkmk.com) OHM should also be able to report S.M.A.R.T. data (which would be interesting for my SSDs), Clock Speeds, Power and more Temperatures (my MB sensors showed up, but CPU and GPU temperature did not). I could only find a rule for OHM S.M.A.R.T. but enabling and/or enforcing it did not get any new services to show up. I could not find rules for any of the other sensors. When I start a “normal” OHM instance all desired data shows up.
Thanks in advance
