Since we updated to 2.0 (currently 2.0.0.p19) the Oracle Checks stopped working on an Oracle Cluster (Version 12.1.0.2.0). It end with this error:
[set_ora_env] ORA-99999 ORACLE_HOME for SID ‘removed’ not found or not existing!
I digged it down to this command getting empty output:
$("${crs_home}"/bin/crsctl stat res -p -w “((TYPE = ora.database.type) and (GEN_USR_ORA_INST_NAME = ${ORACLE_SID}))”
Anyone an idea what maybe the reason and how to fix it?
No Oracle here, so I’m only taking wild guesses:
- did you update the agent plugin(s) on the client as well?
- did you trigger a re-discovery of services on the Oracle host(s)/cluster?
Hi, yes, plugin is updated via backery and the problem is within the plugin.
