I am new to Check_MK and I am using Check_Mk raw.
I try to create a check, which shows the total disk usage of all disks of a host.
The script on the monitored host at /user/lib/check_MKagent/plugins/
contains this:
#!/bin/sh
echo ‘<<<filesystem_df_total_>>>’
df -h --output=size --total | awk ‘END {print $1}’
If I try the output of the check with “check_mk_agent | less” I can find the output of the check “filesystem_df_total” which shows the disk usage in TB
So I created the plugin at the check_mk Server in /opt/omd/sites/sitename/local/lib/check_mk/base/plugins/agent_based
It contains: from .agent_based_api.v1 import *
def discover_filesystem_df_total(section):
yield Service()
register.check_plugin(
name=“filesystem_df_total”,
service_name=“Filesystem df_total”,
discovery_function=discover_filesystem_df_total,
check_function=check_Filesystem_df_total,
But there is no new Service check at the new host.
Am I missing something?
Can you help me please?
Thank you in advance.
kind regards,
cmk_User
ChristianM
(Christian Michaelski)
July 27, 2022, 9:22am
2
Hi.
I think you need the following register settings:
yield Service(item="Filesystem total")
service_name=“%s”,
RG, Christian
Thank you for the fast reply.
I tried your suggested modifications, but there is still no service check appearing.
ChristianM
July 27, 2022, 10:11am
4
Hi.
I hink you need to register also the agent section like this:
def parse_filesystem_df_total(string_table):
section = string_table
return section if section else None
register.agent_section(
name = '_filesystem_df_total',
parse_function = parse_filesystem_df_total,
RG, Christian
Thank you again for you fast reply.
I edited the script like you suggested, but there is still no service check appearing.
It looks like this now:
yield Service(item=“Filesystem total”)
service_name=“%s”,
name = ‘_filesystem_df_total’,
Please use the “Preformatted text” like @ChristianM does. Your code is not readable at the moment.
I am sorry. It looks now like this:
service_name=“%s”,
If the code looks like this - it will not work. Python without correct indentation is broken.
Also the strange single and double quotes will not do.
Please copy the text exactly like it is on your CLI into the preformatted text block.
Thank you for the reply.
That is my exact text:
name="filesystem_df_total",
service_name="%s",
section=string_table
parse_function=parse_filesystem_df_total,
ChristianM
July 28, 2022, 1:08pm
10
Hi.
Looks like, there is a typo in the output of the agent:
need to remove the last character of token in the line with the echo, e.g.
#!/bin/sh
echo ‘<<<filesystem_df_total>>>’
The token must be equal to the name parameter in the register statements.
Now the plugins should detect the data.
RG, Christian
Thank you for finding the typo.
I fixed it, but still no service check
Something must still be wrong.
the agent output looks like this:
#!/bin/sh
echo '<<<filesystem_df_total>>>'
df -h --output=size --total | awk 'END {print $1}'
and the file on the monitored host looks like this:
service_name="%s",
check_function=check_filesystem_df_total,
ChristianM
July 28, 2022, 1:41pm
12
Hi.
In your code, the check function is missing and when you run “cmk --debug -vvII ” you get an exception. The following code wil work:
#!/usr/bin/env python3
def check_filesystem_df_total(item, params, section):
yield Result(state=State.OK, summary="Here Iam")
service_name="%s",
check_default_parameters={},
RG, Christian
Thanks a lot for all the help.
But I’m afraid it is still not working. The cmk --debug command gave no exception.
I also tried to put a “,” after the None in the check function. But that didn’t help either.
service_name="%s",
return section if section else None,
If i use your code, i first get one new check found.
cmk --debug -vvI testhost
1 filesystem_df_total
SUCCESS - Found 1 services
also the check gave the expected output
cmk --debug -vvn testhost
<<<filesystem_df_total>>> / Transition HostSectionParser -> HostSectionParser
No persisted sections
-> Add sections: [... 'filesystem_df_total', ...]
Filesystem total Here Iam
Thank you all for the help.
Yes, the check is now found.
But it appears to be just a static Check with no script output. The output of the script on the monitored host which should monitor the total disk usage accross all disks is not there.
It just looks like this:
But the intention of the check was to monitor the output of and a statistic of that. The percentage is not needed.
It should be similar to the integrated Filesystem check, but just the total usage in TB
The output of df -h --output=size --total | awk 'END {print $1}
’ in the command line is:
1,5T
So the intention was to create a check which outputs this 1,5T and has a statistic of that, where you can see the fluctuation in used space of the disk usage in TB.
ChristianM
July 29, 2022, 9:31am
16
Hi.
You need to fill the check function with a check logic. The example was only to bring you on the right way to get the data from the agent and discover the chekcs. Now it’s on you to finish the plugin for your needs. If you want to see only the value you get, you can write the check function like this:
yield Result(state=State.OK, summary=f"Total: {section[0][0]}")
RG, Christian
Thank you very much.
That was the output I was looking for.
Now I just need to figure out how to create a performance graph out of it.
ChristianM
August 2, 2022, 7:14am
18
Hi.
Please have a look in the check API. There you will find the method’s for metrics.It’s a one liner
RG, Christian
system
(system)
Closed
August 3, 2023, 2:58pm
21
