Add a ‘description’ or ‘comment’ field to each host add single line or multi-line static information.
Add tags to add these fields to email messages.
You are not permitted to view the requested resource.
Hi, you can use the Host Alias field for a static host description/comment. Or can you specify your use case a bit more?
I’m using a “custom host attribute” to solve this task.
Joerg
