Hello All,
I am using Check_MK RAW 2.4.0p5 and the “Cisco Meraki” rule found under Setup > Agents > Other integrations.
**SetupAgentsOther integrationsCisco Meraki[Edit rule: Cisco Meraki](javascript:window.location.reload(false))**
I created a dummy host to configure it and entered the required details.
However, it only adds the “Cisco Meraki Device Status” object.
I add the Meraki devices manually, but only that specific object gets added; is it possible to monitor anything else?
Can I use other plugins?
Regards,
Vix
