Heyho,
i have a Problem to develop an Plugin for check_mk-v2.
The Problem is there there it after some time refused to run.
The Script: cmk_nextcloud/nextcloud.py at master · Serverfrog/cmk_nextcloud (github.com)
The Error Stacktrace:
Error in plugin file /omd/sites/checkfrog/local/share/check_mk/checks/nextcloud: "'__name__' not in globals" Traceback (most recent call last): File "/omd/sites/checkfrog/bin/cmk", line 79, in <module> errors = config.load_all_agent_based_plugins(check_api.get_check_api_context) File "/omd/sites/checkfrog/lib/python3/cmk/base/config.py", line 1415, in load_all_agent_based_plugins errors.extend(load_checks(get_check_api_context, filelist)) File "/omd/sites/checkfrog/lib/python3/cmk/base/config.py", line 1494, in load_checks did_compile |= load_precompiled_plugin(f, check_context) File "/omd/sites/checkfrog/lib/python3/cmk/base/config.py", line 1776, in load_precompiled_plugin exec(marshal.loads(open(precompiled_path, "rb").read()[_PYCHeader.SIZE:]), check_context) File "/omd/sites/checkfrog/local/share/check_mk/checks/nextcloud", line 2, in <module> from .agent_based_api.v1 import * KeyError: "'__name__' not in globals"
I followed the the Wiki Writing your own check plug-ins (checkmk.com) which seems that the Problem is the import which is checkmk-v2 needed
