Hello!
We are currently replacing some inverters from eltek. Unfortunately, with the Smartpack 2 controllers the OID have changed. What would be the right way to get the changes into the plugins?
best regards
Oliver
Hello!
best regards
Oliver
Make a copy of the existing plugins in the ~/local hierarchy and change the plugin name.
Changing OIDs means to create a new plugin. Otherwise the old OIDs could not be fetched any more.
hi, can you share your plugin for the eltek psu?
