I am running SNMPv3 on two stacked switches and main router. All I can see in check_mk are port MAC’s, up/down status and transfer speeds. Is there any way to display external device’s IP address or at least MAC address on each port?
This would be the task of the HW/SW inventory of checkmk as this info is not relevant to system monitoring.
There are some extensions that try to extract this info via SNMP from LLDP or mac switch table sources. But currently this is not built into the checkmk “core” distribution.
E.g.: Checkmk Exchange
