Hey guys
If anyone knows is this plugin is still working?
And if yes - how can I use it? I installed the package via “omd su -> mkp install post…” and I can find it in the agent sektion.
I tried to detect if something automatically will detected and then I tried to use the “/plugins/postfix_processed” as a check but I got this:
/usr/bin/env: ‘lua’: No such file or directory
Is this normal or is that the reason why the check doesn’t work?
Greetz
