Hi. I’m trying to migrate from 1.2.2p2 to 1.6.0.
In old configuration i have something like legacy_checks configured in file. example (It’s just my header, i have many of them):
legacy_checks = [
( ( "check_tcp!80", "TCP HTTP", True), [ "web" ], ALL_HOSTS ),
( ( "check_tcp!443", "TCP HTTPS", True), [ "https" ], ALL_HOSTS ),
etc...
They are using checks from extra_nagios_conf.mk
example:
define command{
command_name check_udp
command_line $USER1$/check_udp -H $HOSTADDRESS$ -p $ARG1$ $ARG2$
They are on server side.
So I want to use them still on new version.
So Now i’ve copied those files to my new configuration.
CMK screams that legacy_checks are deprecated and i should change them to custom_checks - so the files are read and interpreted as they should. After changing to custom_checks all seems to be ok. There are no errors at all.
But there is no sign of those checks on my hosts
There are many documents around web that I should find this now i WATO, but there is no place for this in my config i think.
Can someone help me where should i look for ? Maybe I need some special plugin to read them?
Any help or clue will be appreciated
Thanks
