Hello, everyone.
I’m using Check_MK with version 2.0.0p4 CRE
My agents is updated to Version: 2.0.0p4
At first, I have problem with netifaces_rbl plugin - It simply asked me to perform a manual migration as it described in werk#10601.
So, to spend less time on this, I’ve decide to use this package from Checkmk Exchange.
But after that I’ve expirience some weird behavior of my checkmk. Let me describe:
- I’ve got discovery rule in ruleset RBL, which I didn’t change all that time
- After I’ve done with reinstall of netifaces plugin, it works well and check showed me OK status
- Check_MK Discovery marked that check like vanished service, and when I was trying to fully rediscover services of host, Discovery still show me my check as vanished service
What I’m already trying and it didn’t work:
$ cmk -II agent.name
It remove my check from var/check_mk/autochecks/agent.name conf and I can’t monitore It. I consider this as “didn’t work” for me -
$ cmk --flush agent.name
Same result - I delete previous rule, apply changes and create new. Rediscover with gui and got same result.
If you know where I can find discovery configs on my master, please, let me know. It would help me to better understand how discovery works in checkmk, since there’s no better explanation in docs right now
