**CMK version: Checkmk Raw Edition 2.1.0p11
**OS version: OS: CentOS Linux 7 (Core)
Hello together,
We have the problem that we want to monitor Samba shares with the role “Check SMB share access”, but this only works successfully if the password of the user used for the access does not contain special characters.
When I test the access via net use, it works without problem, only Check_MK reports that the user is not correct (Invalid user:).
What is noticeable is that in the service overview the specified share name is displayed as an addition to the name “SMB Share …” without a $ at the end, although it has a $ at the end in the configuration and in the share itself, and that the password in the details for the check under the item “Service check command” is specified with ! although only a ! but no \ occurs in the password.
How to work around this problem, or have I configured something wrong here?
Thanks for helpful answers
many greetings
Sebastian
