Good day,
I have a rather interesting problem. When I create a notification script in the folder /omd/sites//local/share/check_mk/notifications/ with nano or vi it works. However, if I move the script to a folder with cp or cat then it does not work, and I get the following error message in the notification logs:
FileNotFoundError: [Errno 2] No such file or directory: ‘/omd/sites//local/share/check_mk/notifications/’.
I have now tried it with different users, with different RWX rights, I have tried everything, but it only works when I create it with nano or vi.
I have also tried it with different check_mk versions and on different servers but everywhere occurs the same problem…
It also has nothing to do with the script itself, when I start a script that only outputs a text, the same issue occurs…
I also don’t understand how the file for linux should be different by creating it with nano/vi than with all other methods, I guess it has to do with how check_mk reads the scripts or idk.
Also, for information, it doesn’t work if you open the file with nano after copying it, then saving it and closing it again, so it must have something to do with the creation.
Can anyone perhaps help me?
Thank you!
