CMK version: 2.1.0p8 (cme)
OS version: Ubuntu 20.04 LTS
Cluster collector version: 1.0.1
Warnings:
check_mk: ERROR: Duplicate service description (auto check) 'Info' for host 'pod_local_cattle-system-rancher-webhook-6958cfcddf-82vc8'! - 1st occurrence: check plugin / item: kube_cluster_info / None - 2nd occurrence: check plugin / item: kube_pod_info / None
check_mk: ERROR: Duplicate service description (auto check) 'Info' for host 'pod_local_checkmk-checkmk-kube-agent-node-collector-container-metrics-7x6gj'! - 1st occurrence: check plugin / item: kube_cluster_info / None - 2nd occurrence: check plugin / item: kube_pod_info / None
check_mk: 12 further warnings have been omitted
check_mk: ERROR: Duplicate service description (auto check) 'Info' for host 'pod_local_cattle-fleet-local-system-fleet-agent-57497ff7dc-bwnmd'! - 1st occurrence: check plugin / item: kube_cluster_info / None - 2nd occurrence: check plugin / item: kube_pod_info / None
check_mk: ERROR: Duplicate service description (auto check) 'Info' for host 'namespace_local-checkmk'! - 1st occurrence: check plugin / item: kube_cluster_info / None - 2nd occurrence: check plugin / item: kube_namespace_info / None
check_mk: ERROR: Duplicate service description (auto check) 'Info' for host 'pod_local_kube-system-rke2-coredns-rke2-coredns-687554ff58-l9csh'! - 1st occurrence: check plugin / item: kube_cluster_info / None - 2nd occurrence: check plugin / item: kube_pod_info / None
check_mk: ERROR: Duplicate service description (auto check) 'Info' for host 'pod_local_checkmk-checkmk-kube-agent-cluster-collector-5d46f7b5dd-zmmck'! - 1st occurrence: check plugin / item: kube_cluster_info / None - 2nd occurrence: check plugin / item: kube_pod_info / None
check_mk: ERROR: Duplicate service description (auto check) 'Info' for host 'pod_local_checkmk-checkmk-kube-agent-node-collector-container-metrics-glv77'! - 1st occurrence: check plugin / item: kube_cluster_info / None - 2nd occurrence: check plugin / item: kube_pod_info / None
check_mk: ERROR: Duplicate service description (auto check) 'Info' for host 'namespace_local-cattle-fleet-local-system'! - 1st occurrence: check plugin / item: kube_cluster_info / None - 2nd occurrence: check plugin / item: kube_namespace_info / None
check_mk: ERROR: Duplicate service description (auto check) 'Info' for host 'pod_local_kube-system-kube-proxy-dok-ran-app-002'! - 1st occurrence: check plugin / item: kube_cluster_info / None - 2nd occurrence: check plugin / item: kube_pod_info / None
check_mk: 22 further warnings have been omitted
Ich bin der Anleitung in der Dokumentation gefolgt.
Alles funktioniert, bis auf den Fehler der beim aktivieren der Änderungen auftritt und dass die Kubernetes Node Hosts, die durch das Dynamic host Management erstellt wurden, Fehler haben.
Das Kubernetes Cluster ist das locale Management Cluster einer Rancher Installation.
Kubernetes Engine ist RKE2.
