Hello!
My version of checkmk is raw is 1.6.0p9 . I am trying to configure the oracle plugin mk_oracle following the documentation Monitoring Oracle databases efficiently but I cannot get information from the database in the checkmk. Sure there is something that I am not understanding and I am doing it wrong.I am getting the following error
ORA TEST1 Instance ERROR: ORA-12541: TNS: no listener SP2-0751: Unable to connect to Oracle. Exiting SQL * Plus
I cannot identify where I am failing in the configuration process.I have the following file created and user check_mk created in the database with the permissions it needs to be able to access the information
If your filenames in /etc/check_mk is correct in your post, then you should change the file name from “tnsname.ora” to tnsnames.ora (plural). That’s the name oracle looks for.
