I am very new to use Check_MK tool to setup monitors to pull out all processes running on our Linux Server based on specific User.
From “Process Discovery” page, I had set rules as below.
Process Name: Test %u
Name of the User: Selected “Grab User from found processes”
Select “Default parameters for detected services”
When i checked details on one of the Host WATO Services tab, its not showing up all our process running with the user.
Also tried using “Process Matching” regular expressions, not able to obtain the expected result. Any help or guidance for the documentations to refer for setting up this?
But for the below (higher version of TIBCO process) is not getting monitored as expressions was not matching.
Sample Higher Version PID:
/usr/tibco/TIBCO6x/bw/6.4/domains/tibdev6x/appnodes/AS_MultiAppAS_WC/AN_tibdev6x_N8/bin/bwappnode-AN_tibdev6x_N8 --propFile /usr/tibco/TIBCO6x/bw/6.4/domains/tibdev6x/appnodes/AS_MultiAppAS_WC/AN_tibdev6x_N8/bin/bwappnode-AN_tibdev6x_N8.tra -config /usr/tibco/TIBCO6x/bw/6.4/domains/tibdev6x/appnodes/AS_MultiAppAS_WC/AN_tibdev6x_N8/config.ini
So adjust expressions to match both version of PIDs as below, but its not listing the processes due to issue with Process Name expression. Provided user friendly input under “Process Name” value, still no luck
