2.0.0p23.cee
Proxmox 7
No Services Found for Backup Check Rules
I Confifured the Rule but CheckMK cant find the backups. I need help.
2.0.0p23.cee
Proxmox 7
I have here also 2.0.0p23 cfe in my home installation and it shows all the backups fine on the monitored VMs/Containers.
The backup data is not shown on the Proxmox hosts.
HI Thanks for your answer, according to CheckMK special_proxmox_ve agent is installed but there are no vm infos
p.s. would a agent output help you? identify the problem? if i search for backup in the output file there is no info.
You only need to configure the special agent, no installation normally needed.
For my Proxmox the agent config looks like this.
Hi, thanks for the fast answer, as it seems the problem was that I didn’t enable the “no-cert-check”, now each vm has their backup stamp just as it should be.
