CMK version:2.1.0p1
**OS version: Debian 10 **
**Error message: none - no services found **
Hello CMK-Users,
i created my first Windows Plugin for the new agent. The plugin was written after the guidelines in the main documentation. [ Updates und Upgrades (checkmk.com)]
The powershell script works properly and delivers the correct output. I check that on the windows host and on the cmk server. On the cmk-server shell i can see the <<>> when i ask per cmk command as follows
cmk -d myserver01 | grep -A5 '^<<<rds_session_host'
I placed the corresponding python plugin in /omd/site/local/lib/check_mk/base/plugins/agent_based/ like the documentation says.
Now to the problem:
i cant get any services in the service configuration under the host.
I checked the Output with
cmk -II --debug --detect-plugins=rds_session_host myserver01
i tested also with following command:
cmk --debug -vvn myserver01
i get as output:
<<<rds_session_host>>> / Transition NOOPParser â HostSectionParser
â Add sections: [âcheck_mkâ, âcheckmk_agent_plugins_winâ, âcmk_agent_ctl_statusâ, âdfâ, âdotnet_clrmemoryâ, âfileinfoâ, âlogwatchâ, âmemâ, âpsâ, ârds_session_hostâ, âservicesâ, âsystemtimeâ, âuptimeâ, âwinperf_ifâ, âwinperf_phydiskâ, âwinperf_processorâ, âwmi_cpuloadâ]
Extension
After i tested a bit with it, it seems that the plugin.py gets removed from that path. I saw an error in the service discovery. The plugin seems to crash. However, it cant be right, that the plugin gets removed right?
How can i investigate further ?
