Hi @LaMi ,
why has the function quote_shell_string
been moved from cmk.utils
to cmk.base.cee.plugins.bakery.bakery_api.v1
and is therefor exclusive for CEE bakery plugins now?
I have an extension for check_by_ssh
that uses this function: check_mk_extensions/check_by_ssh at cmk2.2 · HeinleinSupport/check_mk_extensions · GitHub
I have now just copied the code into the check plugin.
