Re trigger all existing unhandled problems
I am having a complete brain fart and can’t think of the best way to achieve this which it’s probably one click of a button.
I need to trigger a new email notification for all unhandled file system alerts, my notifications are set to to notify once, then if it is still an issue notify again a week later.
However how do i get this to force through a “one off” replay notification of the exisitng alert? As I need existing unhandled alerts to generate the notification which inturn will log a ticket to our ticketing system.
If i scheduled a recheck of the service it doesn’t generate a notification. is this because period notifications are turned on?
Thanks and sorry for the silly question!
Notifications are only generated when a service changes its state.
You can configure periodic notifications. These generate a notification in a configurable interval.
But currently there is no possibility to re-send a notification.
You could try and use the command “Fake check result” to set the problematic service to OK manually. After a short time it would be detected as not OK again and a new notification would be generated.
