Whenever a VM needs a reboot to finish updates, CheckMK shows a WARNING. I want to create a rule so when a reboot is required, it can still show Green/OK status.
Any ideas how to achieve that?
I played with the WSUS (Windows Updates) rule, but it looks like I can’t achieve the desired result with that rule.
I suppose Service state translation rule can be the easy and straightforward way to achieve that. But do you know if there a specific rule for the above described purpose?
Out of curiosity, what plugin is providing the service for this?
If not sure, do a ‘service discovery’ and on that page enable plugin names under Display.
We have quite a few windows host using the checkmk agent but I’ve never come across an alert for pending reboot. I’m wondering if it’s WSUS related and if that ruleset might help.
This is what an alert for pending reboot looks like.
The plug-in name is windows_updates, which has WSUS (Windows Updates) as parameter rule set. Though, when I edit a WSUS (Windows Updates) rule, there is no option to edit the optional reboot.
