[Release] Checkmk stable release 2.3.0p27
I am not sure I fully understand.
  1. The service you want to be ignored in called exactly ‘corosync-qdevice.service’?
  2. Even though you defined it in the rule, it’s still shown as Failed?
How it works is that if a service is matched by the regex pattern defined in the rule, it will be added to services_organised[“excluded”]. In your case, it may not be picked up because the of the ‘.’ in the pattern. :thinking:
Yes
Yes
As it is not included inside the list ‘services_organised[“excluded”]’.
That’s why also your modification shows a critical.
Then there some other things are broken as every service has a “.” in the name.
“.” matches every character in regex, so “.” should be matched too?
Okay, thanks! That gives some room to investigate further.
The funny thing is - This check actually never worked as designed. For the failed services it always had an OK state, which should not have been the case.
Give me a couple of hours and I will come back to you with something.
Thanks for the help!
That’s wrong - it worked as it should. If you had a failed service the check goes critical. If you have a failed service and set this service to ignore than it was OK.
What should not have worked before? I have around 3k Linux machines here today and it is working fine.
Hey @andreas-doehler,
Would you mind having a super short call? Looks like you are right, but I want to understand why the service is not included in 'services_organised[“excluded”].
Thanks!
Short conclusion of our call is.
  • the mkp does the right thing
  • the existing systemd service summary has a problem with compiling and comparing of regex expressions
  • this regex problem needs also to be fixed before the check will work in a correct way
Due to the fact of above i will postpone upgrading to said version.
Even tho a patch ( in the form of an .MKP) has been provided i think its better to wait for a/the next release.
  • Glowsome
Hey Andreas,
Would you mind testing this MKP out?
systemd_units-0.0.2.mkp (7.9 KB)
This one should ideally address all of the issues you mentioned in your comment.
Thanks!
Looks good - no error message on a host where the regex problem was existing.
Now it shows 1 failed and 1 ignored service and stays OK as the failed service is the ignored one. I will have a look today on a bigger system if it is the same there.
Thanks for your help! But I still dont know how to handle this hotfixes :slight_smile:
Regards,
Bastian
Hey Bastian,
As soon as I know in which version the hotfix will end up, I will let you know.
Best,
Luka
Hello everyone!
Just wanted to let you know that the fix (the code from the newest MKP) will be available with 2.3.0p28. The release is scheduled for today/tomorrow.
If you are using the MKP, once you upgrade to p28, you can disable it.
Thank you for the help and sorry for any inconvenience caused by this!
Best,
Luka
