hi,
is there any best practice to remove a slave from master?
Delete the slave is not possible because there are hosts in it. Delete Hosts not possibe if sync not works.
Ideas?
Thanks in advanced…
hi,
Ideas?
Thanks in advanced…
Look in $OMD_ROOT/etc/check_mk/multisite.d/sites.mk
, you should be able to just remove the site connection there with a text editor.
If you use CEE with liveproxyd the site is also configured in $OMD_ROOT/etc/check_mk/liveproxyd.mk
After removing the site edit your hosts in WATO to be monitored on the master site or delete them.
Make a backup copy before editing the files.
