I have several ports on one of our switches that regularly hit the warn/crit on the bandwidth. Is there a way to do a rule for service retries ton these port bandwidth only?
I was going to try and do a service retry rule on the port(service) but if I did a rule that would give about 15 min before it would trigger the bandwidth warn/crit I think that it would also delay it if the port went down or we started getting packet discards.
The retry is every time for the whole service. Your assumption is correct that this also affects the other checked values.
What you can try is to use the average value option with a time frame of 10 or 15 minutes. This should only affect the bandwidth and the error counters.
This is the only option i can see what you can use for your problem.
