Search and filter function for host and service problems
similar to the search and filter function in the folders
WATO - Hosts -… Folder
You mean for the dashboard?
If it is a view you can extend the filters by yourself. On most views only a minimum amount of filter options are selected.
no not as complicated, simply the same search-bar as you can find at
WATO - HOSTS
where I can for example simply enter ap-de.* or other regex like ^sw-de, Interfac.*, …
to filter in aktuell Host or Service Problems
Something like table filter in Excel
