Hi, I´m experiencing some problems with a nexus 7700. When I created it in my site,the number of services were about 900 but after new discoverys they have decreased to 300 (it seems like it’s just being applied if64 and only interfaces appear …I´ve tried rediscovery but without results…Any idea?
FETCHING DATA
[snmp] Execute data source
No piggyback files for ‘mydevice’. Skip processing.
No piggyback files for ‘10.1.69.45’. Skip processing.
EXECUTING INVENTORY PLUGINS
Plugins: inv_if snmp_extended_info snmp_info
SUCCESS - Found 8563 inventory entries
SUCCESS - Found 1208 status entries
~$ cmk -IIv DCESCCORE01_CPD
Discovering services on: mydevicenexus
DCESCCORE01_CPD:
FETCHING DATA
No piggyback files for ‘mydevicenexus’. Skip processing.
EXECUTING DISCOVERY PLUGINS (6)
302 if64
1 snmp_info
1 snmp_uptime
SUCCESS - Found 304 services, no host labels
I created a rule in [Network Interface and Switch Port Discovery] in the main directory:
Appearance of network interface:
Use alias
Network interface port states to discover:
1 - up, 2 - down
Network interface port types to discover: Selected all of them
Finally I´ve been able to discover all the services, I tried: cmk --check --checks plugin_name -nv --debug mynexusdevice and that worked for me!
The problem is that the discovery process is not applying correctly all the plugins just only 6. Here´s the output:
Trying discovery with: hr_mem, snmp_uptime, if64_tplink, if64adm, if64, snmp_info
Try aquire lock on /omd/sites/lancpds/var/check_mk/autochecks/mynexusdevice.mk
Got lock on /omd/sites/lancpds/var/check_mk/autochecks/mynexusdevice.mk
Releasing lock on /omd/sites/lancpds/var/check_mk/autochecks/mynexusdevice.mk
Released lock on /omd/sites/lancpds/var/check_mk/autochecks/mynexusdevice.mk
303 if64
1 snmp_info
1 snmp_uptime
SUCCESS - Found 305 services, no host labels
where can I find the configuration of the plugins that are being applied to my device?, maybe something is wrong…
