Hello Everyone,
I have been working on some SNMP based checks and I’m nearly ready to publish the first one based on ISIS-MIB.
I found lots of helpful information on the snmp-plugin-basics thread as well as the Phion-MIB example referenced in the article
I also found a helpful template created by @Jiuka, which I’ve decided to use.
I believe the steps I have left to publish this check to the exchange are:
- Write tests (this is where I need tips/direction)
- Understand and configure devcontainer and environment. (package config?)
- Create .mkp file (the process looks straight forward)
Steps1/2 are where I need the most help. This is my first time using a devcontainer with vscode, and I may have missed something. The check currently works, so I’m researching tests and devcontainers to try to fill in my missing knowledge, so I can publish something of good quality the community can use. I would be grateful for any help/direction that might speed up the process.
Cheers,
Curtis
