SNMP checks not working
Hi everyone
We have issues with our SNMP monitor. None of the hosts with snmp monitored works. It only shows Check_MK HW/SW Inventory
Our version is 1.5.0p11
It seems the issue happen when we upgrade from 1.4 to 1.5
Any help is appreciate.
Thanks,
Louis
Did you customize the tag group “Agent Type” in 1.4?
What is the current status of the Data Source configuration settings of the affected hosts?
Hi Sander,
This is current configuration of data sources:
Regarding tag group agent type, I’m not sure where it is setup as I am new to checkmk.
Thank you.
@tmnguyen try to change
Check_MK Agent to Contact either Check_MK Agent or use datasource program
and test it
Hi @neeloj
After changing as suggested, I got this:
I Have also a Problem with the Inventory:
but make a test on the consol with cmk -i
look here:
Greets
When I tried on CLI with cmk -vI command on the host:
  • FETCHING DATA
    [snmp] Execute data source
    [snmp] ERROR: too many values to unpack
  • EXECUTING DISCOVERY PLUGINS (0)
    SUCCESS - Found nothing new
I also tried to create a new site with same version, it works fine.
So, there’s something wrong with current site but I don’t know where yet.
any updates or problem solved ???
