CMK version: 2.0.0p29 (CEE)
**OS version:**RHLE8
Error message: it just doesn’t detect any services, connection test fails but snmpwalk works
cmk --debug -vvII host.xxx
Discovering services and host labels on: host.xxx
host.xxx:
+ FETCHING DATA
[cpu_tracking] Start [7fe36d2ef910]
[TCPFetcher] Fetch with cache settings: DefaultAgentFileCache(base_path=PosixPath('/omd/sites/CGNGER/tmp/check_mk/cache/hawkeye.cgn.cleverbridge.com'), max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
Not using cache (Does not exist)
Connecting via TCP to 10.0.32.224:6556 (5.0s timeout)
Closing TCP connection to 10.0.32.224:6556
[cpu_tracking] Stop [7fe36d2ef910 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
Trying to acquire lock on /omd/sites/CGNGER/var/check_mk/crashes/base/73f13c8e-95a5-11ed-8fc1-0050568b9bee/crash.info
Got lock on /omd/sites/CGNGER/var/check_mk/crashes/base/73f13c8e-95a5-11ed-8fc1-0050568b9bee/crash.info
Releasing lock on /omd/sites/CGNGER/var/check_mk/crashes/base/73f13c8e-95a5-11ed-8fc1-0050568b9bee/crash.info
Released lock on /omd/sites/CGNGER/var/check_mk/crashes/base/73f13c8e-95a5-11ed-8fc1-0050568b9bee/crash.info
File "/omd/sites/CGNGER/bin/cmk", line 92, in <module>
File "/omd/sites/CGNGER/lib/python3/cmk/base/modes/__init__.py", line 69, in call
return handler(*handler_args)
File "/omd/sites/CGNGER/lib/python3/cmk/base/modes/check_mk.py", line 1542, in mode_discover
discovery.do_discovery(
File "/omd/sites/CGNGER/lib/python3/cmk/base/discovery.py", line 370, in do_discovery
fetcher_messages=list(
File "/omd/sites/CGNGER/lib/python3/cmk/base/checkers/_checkers.py", line 238, in fetch_all
raw_data = source.fetch()
File "/omd/sites/CGNGER/lib/python3/cmk/base/checkers/_abstract.py", line 163, in fetch
return fetcher.fetch(self.mode)
File "/omd/sites/CGNGER/lib/python3/cmk/fetchers/_base.py", line 251, in fetch
return result.OK(self._fetch(mode))
File "/omd/sites/CGNGER/lib/python3/cmk/fetchers/_base.py", line 274, in _fetch
self.open()
File "/omd/sites/CGNGER/lib/python3/cmk/fetchers/tcp.py", line 75, in open
self._socket.connect(self.address)
ConnectionRefusedError: [Errno 111] Connection refused
cmk --snmpwalk -vv host.xxx
host.xxx:
Walk on ".1.3.6.1.2.1"...
Executing BULKWALK of ".1.3.6.1.2.1" on host.xxx
Executing SNMP GET of .1.3.6.1.2.1 on host.xxx
=> [None] NOSUCHOBJECT
0 variables.
Walk on ".1.3.6.1.4.1"...
Executing BULKWALK of ".1.3.6.1.4.1" on host.xxx
.1.3.6.1.4.1.39165.1.1.0 => [b'TV-IP420P'] 'OCTETSTR'
.1.3.6.1.4.1.39165.1.2.0 => [b'0'] 'OCTETSTR'
.1.3.6.1.4.1.39165.1.3.0 => [b'V5.4.3 build 180621'] 'OCTETSTR'
.1.3.6.1.4.1.39165.1.4.0 => [b'3c-8c-f8-a2-81-62'] 'OCTETSTR'
.1.3.6.1.4.1.39165.1.5.0 => [b'88'] 'OCTETSTR'
.1.3.6.1.4.1.39165.1.6.0 => [b'IPcamera'] 'OCTETSTR'
.1.3.6.1.4.1.39165.1.7.0 => [b'15 PERCENT'] 'OCTETSTR'
.1.3.6.1.4.1.39165.1.8.0 => [b'0.0 GB'] 'OCTETSTR'
.1.3.6.1.4.1.39165.1.9.0 => [b'0 PERCENT'] 'OCTETSTR'
.1.3.6.1.4.1.39165.1.10.0 => [b'256 MB'] 'OCTETSTR'
.1.3.6.1.4.1.39165.1.11.0 => [b'82 PERCENT'] 'OCTETSTR'
.1.3.6.1.4.1.39165.1.12.0 => [b'0'] 'INTEGER'
.1.3.6.1.4.1.39165.1.13.0 => [b'0.0.0.0'] 'IPADDR'
.1.3.6.1.4.1.39165.1.14.0 => [b'0.0.0.0'] 'IPADDR'
.1.3.6.1.4.1.39165.1.15.0 => [b'0.0.0.0'] 'IPADDR'
.1.3.6.1.4.1.39165.1.16.0 => [b'10.0.32.224'] 'IPADDR'
.1.3.6.1.4.1.39165.1.17.0 => [b'255.255.255.0'] 'IPADDR'
.1.3.6.1.4.1.39165.1.18.0 => [b'10.0.32.254'] 'IPADDR'
.1.3.6.1.4.1.39165.1.19.0 => [b'2023-01-16 14:58:22'] 'OCTETSTR'
.1.3.6.1.4.1.39165.1.20.0 => [b'1'] 'INTEGER'
.1.3.6.1.4.1.39165.1.21.0 => [b'H.264'] 'OCTETSTR'
.1.3.6.1.4.1.39165.1.22.0 => [b'MJPEG'] 'OCTETSTR'
.1.3.6.1.4.1.39165.1.23.0 => [b'1'] 'INTEGER'
.1.3.6.1.4.1.39165.1.24.0 => [b'1'] 'INTEGER'
.1.3.6.1.4.1.39165.1.25.0 => [b'0'] 'INTEGER'
.1.3.6.1.4.1.39165.1.26.0 => [b'1'] 'INTEGER'
.1.3.6.1.4.1.39165.1.27.0 => [b'1'] 'INTEGER'
.1.3.6.1.4.1.39165.1.28.0 => [b'1'] 'INTEGER'
.1.3.6.1.4.1.39165.1.29.0 => [b'ETHERNET'] 'OCTETSTR'
.1.3.6.1.4.1.39165.1.30.0 => [b'1'] 'INTEGER'
.1.3.6.1.4.1.39165.1.31.0 => [b'1'] 'INTEGER'
.1.3.6.1.4.1.39165.1.32.0 => [b'0.0.0.0'] 'IPADDR'
.1.3.6.1.4.1.39165.1.33.0 => [b'ntp.xxxx'] 'OCTETSTR'
.1.3.6.1.4.1.39165.1.34.0 => [b'0'] 'INTEGER'
.1.3.6.1.4.1.39165.1.34.0 => [b'ENDOFMIBVIEW'] 'ENDOFMIBVIEW'
34 variables.
