Guys,
SNMP v2c. Dell EMC DataDomain.
From same host. Different CMK servers.
CEE 1.2.6p16, perfect, i get all services. CEE 1.4.0p38, perfect, i get all services CEE 1.6.0p9, error.
Starting job…
FETCHING DATA
[agent] Execute data source
[agent] ERROR: Communication failed: timed out
[snmp] Execute data source
SNMP scan failed: Cannot fetch system description OID .1.3.6.1.2.1.1.1.0. This might be OK for some bogus devices. In that case please configure the ruleset “Hosts without system description OID” to tell Check_MK not to fetch the system description and system object OIDs.
Simple and perfect. That told me a lot.
It seems to be it was/it is a lot of info.
[snmp] emc_datadomain_disks: Fetching data
Executing BULKWALK of “.1.3.6.1.4.1.19746.1.6.1.1.1.1” on VTL-PRPM001
ERROR: SNMP error 0/-24 (Timeout)
[snmp] ERROR: SNMP Error on VTL-PRPM001: SNMP query timed out after 4 tries within 4.00 seconds
I modified “snmp timing” to 30 seconds, and that do the job.
I think your device has a problem with bulkwalk if it needs such timing settings.
You can also try to disable bulkwalk for this device a look at the execution time of your query.
