Moin,
erst einmal vielen Dank für die hilfreichen Kommandos.
Jetzt verstehe ich jedoch nicht, wieso das Gerät falsche Antworten zurück gibt.
Der Switch sollte doch mindestens die Standard-SNMP Antworten geben,
OMD[MYSITE]:~$ cmk -D hostname
Addresses: 10.135.XX.XX
Tags: [address_family:ip-v4-only], [agent:special-agents], [criticality:prod], [ip-v4:ip-v4], [networking:lan], [piggyback:auto-piggyback], [site:MYSITE], [snmp:snmp], [snmp_ds:snmp-v2], [tcp:tcp]
Labels:
Host groups: check_mk
Contact groups: all
Agent mode: No Checkmk agent, all configured special agents
Type of agent:
SNMP (Credentials: ‘authPriv, md5, snmp_credentials, snmp_credentials, DES, snmp_credentials’, Bulk walk: yes, Port: 161, Inline: yes)
Process piggyback data from /omd/sites/MYSITE/tmp/check_mk/piggyback/10.135.XX.XX
Services:
checktype item params description groups
OMD[MYSITE]:~$ cmk --debug -vvI 10.135.XX.XX
Discovering services on: 10.135.XX.XX
10.135.XX.XX:
FETCHING DATA
[snmp] No persisted sections loaded
[snmp] Not using cache (Don’t try it)
[snmp] Execute data source
SNMP scan:
Getting OID .1.3.6.1.2.1.1.1.0: Executing SNMP GET of .1.3.6.1.2.1.1.1.0 on 10.135.XX.XX
=> [‘Alcatel-Lucent OS6850E-24 6.4.6.440.R01 Service Release, May 10, 2018.’] OCTETSTR
Getting OID .1.3.6.1.2.1.1.2.0: Executing SNMP GET of .1.3.6.1.2.1.1.2.0 on 10.135.XX.XX
=> [‘.1.3.6.1.4.1.6486.800.1.1.2.1.7.1.46’] OBJECTID
Using cached OID .1.3.6.1.2.1.1.2.0: .1.3.6.1.4.1.6486.800.1.1.2.1.7.1.46
Using cached OID .1.3.6.1.2.1.1.1.0: Alcatel-Lucent OS6850E-24 6.4.6.440.R01 Service Release, May 10, 2018.
Getting OID .1.3.6.1.4.1.232.2.2.4.2.0: Executing SNMP GET of .1.3.6.1.4.1.232.2.2.4.2.0 on 10.135.XX.XX
=> [None] NOSUCHOBJECT
failed.
BULKWALK GEKÜRZT
SNMP scan found alcatel_cpu alcatel_fans alcatel_power alcatel_temp hr_mem if64 mgmt_snmp_info mgmt_snmp_uptime snmp_info snmp_uptime
SNMP filtered check plugin names alcatel_cpu alcatel_fans alcatel_power alcatel_temp hr_mem if64 snmp_info snmp_uptime
Try aquire lock on /omd/sites/MYSITE/tmp/check_mk/snmp_scan_cache/10.135.XX.XX.10.135.XX.XX
Got lock on /omd/sites/MYSITE/tmp/check_mk/snmp_scan_cache/10.135.XX.XX.10.135.XX.XX
Releasing lock on /omd/sites/MYSITE/tmp/check_mk/snmp_scan_cache/10.135.XX.XX.10.135.XX.XX
Released lock on /omd/sites/MYSITE/tmp/check_mk/snmp_scan_cache/10.135.XX.XX.10.135.XX.XX
[snmp] alcatel_cpu: Fetching data
Executing BULKWALK of “.1.3.6.1.4.1.6486.800.1.2.1.16.1.1.1.13” on 10.135.XX.XX
.1.3.6.1.4.1.6486.800.1.2.1.16.1.1.1.13.0 => [26] ‘INTEGER’
[snmp] alcatel_fans: Fetching data
Executing BULKWALK of “.1.3.6.1.4.1.6486.800.1.1.1.3.1.1.11.1.2” on 10.135.XX.XX
.1.3.6.1.4.1.6486.800.1.1.1.3.1.1.11.1.2.569.1 => [2] ‘INTEGER’
.1.3.6.1.4.1.6486.800.1.1.1.3.1.1.11.1.2.569.2 => [2] ‘INTEGER’
.1.3.6.1.4.1.6486.800.1.1.1.3.1.1.11.1.2.569.3 => [2] ‘INTEGER’
[snmp] alcatel_power: Fetching data
Executing BULKWALK of “.1.3.6.1.4.1.6486.800.1.1.1.1.1.1.1.2” on 10.135.XX.XX
.1.3.6.1.4.1.6486.800.1.1.1.1.1.1.1.2.1 => [1] ‘INTEGER’
.1.3.6.1.4.1.6486.800.1.1.1.1.1.1.1.2.65 => [1] ‘INTEGER’
.1.3.6.1.4.1.6486.800.1.1.1.1.1.1.1.2.97 => [1] ‘INTEGER’
.1.3.6.1.4.1.6486.800.1.1.1.1.1.1.1.2.569 => [1] ‘INTEGER’
Executing BULKWALK of “.1.3.6.1.4.1.6486.800.1.1.1.1.1.1.1.36” on 10.135.XX.XX
ERROR: SNMP error 5/1 ((genError) A general failure occured)
[snmp] ERROR: SNMP Error on 10.135.XX.XX while walking .1.3.6.1.4.1.6486.800.1.1.1.1.1.1.1.36. Normally this is caused by a device sending invalid SNMP responses (Details: (genError) A general failure occured (5/1)).
File “/omd/sites/MYSITE/bin/cmk”, line 94, in
File “/omd/sites/MYSITE/lib/python/cmk_base/modes/init.py”, line 72, in call
return mode.handler_function(*handler_args)
File “/omd/sites/MYSITE/lib/python/cmk_base/modes/check_mk.py”, line 1498, in mode_discover
discovery.do_discovery(hostnames, options.get(“checks”), options[“discover”] == 1)
File “/omd/sites/MYSITE/lib/python/cmk_base/discovery.py”, line 134, in do_discovery
multi_host_sections = _get_host_sections_for_discovery(sources, use_caches=use_caches)
File “/omd/sites/MYSITE/lib/python/cmk_base/discovery.py”, line 906, in _get_host_sections_for_discovery
return sources.get_host_sections(max_cachefile_age)
File “/omd/sites/MYSITE/lib/python/cmk_base/data_sources/init.py”, line 279, in get_host_sections
host_sections_from_source = source.run()
File “/omd/sites/MYSITE/lib/python/cmk_base/data_sources/abstract.py”, line 133, in run
raw_data, is_cached_data = self._get_raw_data()
File “/omd/sites/MYSITE/lib/python/cmk_base/data_sources/abstract.py”, line 182, in _get_raw_data
raw_data = self._execute()
File “/omd/sites/MYSITE/lib/python/cmk_base/data_sources/snmp.py”, line 233, in _execute
self._use_snmpwalk_cache)
File “/omd/sites/MYSITE/lib/python/cmk_base/snmp.py”, line 214, in get_snmp_table
use_snmpwalk_cache)
File “/omd/sites/MYSITE/lib/python/cmk_base/snmp.py”, line 538, in _get_snmpwalk
rowinfo = _perform_snmpwalk(snmp_config, check_plugin_name, oid, fetchoid)
File “/omd/sites/MYSITE/lib/python/cmk_base/snmp.py”, line 562, in _perform_snmpwalk
context_name=context_name)
File “/omd/sites/MYSITE/lib/python/cmk_base/cee/inline_snmp.py”, line 201, in walk
(snmp_config.hostname, oid, err_str, err_num, err_ind))
cmk_base.exceptions.MKSNMPError: SNMP Error on 10.135.XX.XX while walking .1.3.6.1.4.1.6486.800.1.1.1.1.1.1.1.36. Normally this is caused by a device sending invalid SNMP responses (Details: (genError) A general failure occured (5/1)).
OMD[MYSITE]:~$ cmk --debug -vvn 10.135.XX.XX
[cpu_tracking] Start with phase ‘busy’
Check_MK version 1.6.0p12
Try aquire lock on /omd/sites/MYSITE/tmp/check_mk/counters/10.135.XX.XX
Got lock on /omd/sites/MYSITE/tmp/check_mk/counters/10.135.XX.XX
Releasing lock on /omd/sites/MYSITE/tmp/check_mk/counters/10.135.XX.XX
Released lock on /omd/sites/MYSITE/tmp/check_mk/counters/10.135.XX.XX
Loading autochecks from /omd/sites/MYSITE/var/check_mk/autochecks/10.135.XX.XX.mk
FETCHING DATA
[cpu_tracking] Push phase ‘snmp’ (Stack: [‘busy’])
[snmp] Write data to cache file /omd/sites/MYSITE/tmp/check_mk/data_source_cache/snmp/10.135.XX.XX
Try aquire lock on /omd/sites/MYSITE/tmp/check_mk/data_source_cache/snmp/10.135.XX.XX
Got lock on /omd/sites/MYSITE/tmp/check_mk/data_source_cache/snmp/10.135.XX.XX
Releasing lock on /omd/sites/MYSITE/tmp/check_mk/data_source_cache/snmp/10.135.XX.XX
Released lock on /omd/sites/MYSITE/tmp/check_mk/data_source_cache/snmp/10.135.XX.XX
[cpu_tracking] Pop phase ‘snmp’ (Stack: [‘busy’, ‘snmp’])
[cpu_tracking] Push phase ‘agent’ (Stack: [‘busy’])
[piggyback] No persisted sections loaded
No piggyback files for ‘10.135.XX.XX’. Skip processing.
[cpu_tracking] Pop phase ‘agent’ (Stack: [‘busy’, ‘agent’])
[cpu_tracking] End
OK - [snmp] Success, execution time 0.0 sec | execution_time=0.006 user_time=0.000 system_time=0.000 children_user_time=0.000 children_system_time=0.000 cmk_time_snmp=0.002 cmk_time_agent=0.001
